01-16-2023 12:08 AM
Hello.
In the link below, it is introduced that the VISA function corresponding to ibask in ni4882.dll is viGetAttribute, but is there a list of constants for viGetAttribute corresponding to each option of ibask somewhere?
https://www.ni.com/docs/ja-JP/bundle/ni-visa/page/ni-visa/board-levelprogramming.html
I want to call IbaSerialNumber from VISA without using ibask.
I tried assigning the constant 0x0023 of IbaSerialNumber to viGetAttribute, but of course an error occurred.
01-18-2023 06:10 AM - edited 01-18-2023 06:11 AM
Hi Iwa6,
Can you show more information about the error message or show us the picture to be clearer?
Regards)
01-18-2023 06:34 AM
Hello l.hovs.
Thank you for reply.
VISA gives an error that the constant does not exist.
01-18-2023 10:40 PM
01-19-2023 10:45 PM
Hello l.hovs
Unfortunately the link you provided does not solve the problem.
This is because we know in advance that the reason for the error is that the property corresponding to 0x23 does not exist in viGetAttribute.
What I want to know is the viGetAttribute constant that corresponds to ibask's ibaSerialNumber(0x23). (If there is no way to know the serial number other than ibask, we welcome the provision of information to that effect.)
Also, I'm not using LabVIEW.
02-07-2023 06:31 AM
Hi Iwa6,
I was wondering why you are avoiding using ibask as long as it is working?
About the error message, I doubt that there is something wrong with code in line 9, there should be call function in front of serial number (0x00000023).
Regards)
02-12-2023 05:41 PM
Hello.
The purpose was to complete with VISA without using ibask.
Finally, I tried brute force (all Long type numbers) with viGetAttribute, but there was no constant equivalent to IbaSerialNumber.
02-15-2023 08:22 AM
Hi Iwa6,
If you are using USB seral port for VISA, here is "VI_ATTR_USB_SERIAL_NUM" command attribute for getting the serial number. You should put this in front of the seral number (0x00000023). Try to complete that in your side and see the results.
Regards)
