Visa Driver Error -1073807202
Can you attach the NI-Max communications with the instrument along with the port configuration for your instrument in NI-Max?
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
Message 11 of 15
(964 Views)
this communicaton was performed with NI MAX with a Microwave Synthesizer.
1: Write Operation (*IDN?\n)
Return Count: 6 bytes
2: Read Operation
Return Count: 47 bytes
Phase\sMatrix,FSW-0020,00000108,1330100248,0100\n
I can also read the current device temperature (after translation of the hex code "00D7": 21,5°C):
3: Write Operation (10)
Return Count: 2 bytes
4: Read Operation
Return Count: 5 bytes
00D7\n
I can even switch on the RF output which I can confirm as my MW power detecting diode shows me a jump in voltage:
5: Write Operation (0F01)
Return Count: 4 bytes
For the fiber thermometer it is very similar: similar communication, correct answers, but same VISA Error -1073807202.
Communication standard specified by the manufacturer:
This port is USB 2.0 compatible and is utilized as a standard COM port (serial port) on the host PC. The serial data buffer for this port is 64-bytes long (including the terminator); thus, it is important not to exceed this length on any command data. All commands must be terminated by a termination character (13, 0X0D). The serial port parameters on the host PC must be set as 8 bits, no parity, 1 stop bit, 115200 baud, no flow control.
I have attached a picture of my NI MAX configurations (sorry for German language in MAX).
I'm still absolutely clueless why communication via MAX works, but not with a LabVIEW VI...
WBR
Message 12 of 15
(955 Views)
can you also send the .vi?
Message 13 of 15
(952 Views)
In NI-Max, you show the interface  as COM5 while in your code you have it entered as COM4.
Message 14 of 15
(947 Views)
Hello everyone,
in the mean time I found the solution to my problem: Even though my system is set up as a 64bit Windows, I should use LabVIEW in the 32bit variant.
Now I can communicate properly and build VIs as I need them. For my understanding, do you have an idea why I can't use 64bit LabVIEW? Did anybody else notice this before?
Thank you very much for your help!
Message 15 of 15
(932 Views)
