Visa NI versus Agilent
I use LV 8.6 to drive some equipements with VISA LXI, IVI and so one and I have a new digitizer to drive which requires Agilent I/O library. When I install Agilent I/O, the installshield find another version of VISA (NI's one) and ask me if I want to replace it by the Agilent's one.
I don't want to break my system (I want to continue to be able to drive my others equipements) but if I don't install the Agilent VISA, I'm not sure to be able to drive the digitizer with the Agilent softwares (MD1).
What is the best solution ? Can I replace the NI version or not? It is possible to switch dll file or change path location?
By advance, thanks,
Benjamin
(3,830 Views)
You should be able to install Agilent as a secondary VISA, leaving NI-VISA as your primary VISA.
(3,818 Views)
If I install it as secondary, is the "Agilent MD1 standalone software" and the "Agilent MD1 LabVIEW instrument driver" will work correctly ?
How can I ask to these apllications to use the secondary VISA driver instead of the primary ?
(3,805 Views)
Is someone already did it and can tell me if it works. I have a lot af LabVIEW instrumentation programs on my computer  and I don't want to break the configuration. For the moment I use 2 différents computers but is not convenient.
(3,777 Views)
I have both NI-VISA and Agilent IO Control 16 installed on my development desktop PC.
The Agilent VISA is secondary, and the NI-VISA is primary.
No problems.
(3,773 Views)
