 CatherineH
			CatherineH
			03-24-2012 02:23 PM
I am trying to interface to the PM100 thorlabs power meter (not the current generation, but an obsolete model) with a computer via a serial-to-usb interface. When I send the *IDN? command to COM3 (USB Serial Port) in the VISA interactive control, the return status is "xBFFF0015". I have the serial port settings the same as the output of the power meter (2400 Baud, 8 data bits, 1 stop bit, no parity).
 Dennis_Knutson
			Dennis_Knutson
			03-24-2012 03:15 PM
 nyc_(is_out_of_
			nyc_(is_out_of_03-24-2012 03:24 PM
Take the USB-serial cable out of the equation, and use a computer with a real serial port, and use Hyperterminal to communicate with the device.
That will tell you alot about the termination required and everything else.
03-25-2012 01:06 PM
I unplugged the USB serial cord from a USB hub at the front of my computer and plugged it in the back, and now it works. I don't really understand why :s 😛
