Interfacing pm100 thorlabs power meter with NI-VISA through usb-serial
I am trying to interface to the PM100 thorlabs power meter (not the current generation, but an obsolete model) with a computer via a serial-to-usb interface. When I send the *IDN? command to COM3 (USB Serial Port) in the VISA interactive control, the return status is "xBFFF0015". I have the serial port settings the same as the output of the power meter  (2400 Baud, 8 data bits, 1 stop bit, no parity).
(5,404 Views)
You could have the wrong type of serial cable, sent the wrong command, sent the wrong terminator, sent no terminator.
(5,402 Views)
Take the USB-serial cable out of the equation, and use a computer with a real serial port, and use Hyperterminal to communicate with the device.
That will tell you alot about the termination required and everything else.
(5,400 Views)
I unplugged the USB serial cord from a USB hub at the front of my computer and plugged it in the back, and now it works. I don't really understand why :s 😛
(5,394 Views)
