Watlow F4 Digital Input (Pause, Start, Terminate)
Has anyone had any luck using the digital inputs on the Watlow F4 controller?  Once the profile is running I cant pause, start, or terminate it using the digital inputs.
I've been using the NI drivers and everything else is working but I've hit a roadblock with this.  Any help would be appreciated.
Thanks.
Message 1 of 11
(7,760 Views)
Problem solved.
If anyone runs into this problem in the future here is the explanation:
Digital inputs are only toggled from high to low, or vice versa, through a ~5V signal to the proper connection in the rear of the controller.  This connection and related information is listed in the manual.  However, I wanted to do trigger the same response (in order to hold, resume, and terminate) using MODBUS communication.  Instead of trying to write to the Digital In registers (1060-1067), which only configures the 4 Digital In's, write to the appropriate "key press simulation" registers.
They are 1210, 1209, and 1217 respectively.
Regards
David
Message 2 of 11
(7,737 Views)
Give me your mail id , i will send you the solution.
we have developed complete software to datalogg, profile programming, trending, PID tunning for Watlow F4 controller (S and D for Both)
Message 3 of 11
(7,723 Views)
Wow,
Thank you kaustubh, I wasn't expecting that!
My e-mail is RevDave@cox.net
Best Regards,
David
Message 4 of 11
(7,695 Views)
kaustubh,
Can you email me your program?  thanks in advance.  I am new to GPIB.
thanks
Message 5 of 11
(7,470 Views)
Hey Kaustubh!
If you would like, we might be able to post your driver on instrument driver network on ni's website for future use!  Thank you!
Best Regards,
Song Mu
National Instruments San Diego
Message 6 of 11
(7,453 Views)
Will these commands allow you to programmtically start a previously created profile?  It seems like this would only work for a profile that is already running.  I was hoping to be able to start a previously created profile through labview.
Message 7 of 11
(7,399 Views)
Hey Drummania!
I believe kaustubh has developed a working driver for the F4, perhaps you could leave your email, and he could send it to you so that you might reference it!  I am not sure if he is still monitoring this thread!
Best Regards,
Song Mu
Message 8 of 11
(7,360 Views)
I read the solution provided to terminate a profile, but I am not sure how to do this. I have tried using the digital input VI for the wlf4 driver, but this does not seem to fix my problem. kaustubh, could you please help me on this? Thanks.
Message 9 of 11
(6,874 Views)
hi
Do you have a solution to control the watlow F4 controller?
Message 10 of 11
(5,503 Views)
