Slower GPIB communication performance after upgrading from Windows NT to Windows XP
I detected an overhead of ~5% in GPIB bus communication time when moving from WinNT to WinXP. I use the same hardware (Intel PC, 2.4GHz) just two disks with different OS. Is it a knowing performance issue of Windows XP? Is there a fix or workaround to reduce this overhead?
(2,881 Views)
Accepted by topic author LTXC_Mike
Hi!
What kind of interface do you use?
Is it a NI-488.2 interface? If so, maybe the following link can help you to increase your performance.
http://zone.ni.com/devzone/cda/tut/p/id/3275
(2,857 Views)
