gpib
Greetings -
New to NI - currently reading LabView for everyone and LabView Student Edition.
Goal:
To communicate with several devices (Agilent Multimeters, Chroma Power Supplies) using NI's GPIB - USB - HS device. Sample VI's/tutorials don't seem to exist; neither of the books cover it in detail. Any advice would be surely appreciated,
(3,205 Views)
What sort of examples were you looking for? You need to define the problem before you can formulate a solution. In other words, you need to define what you are trying to do. I would suggest that in addition to those books you also peruse other information. To learn more about LabVIEW it is recommended that you go through the introduction material, tutorial(s), and other material in the NI Developer Zone's Learning Center which provides links to other materials and other tutorials. There are also several Technical Resources. You can also take the online courses for free.
You should also look in IDNET as that has lots of drivers, and you may find pre-written drivers for the specific instruments you need to control.
(3,195 Views)
