What do I need to run a compiled vrsn of a serial interface ?
I compiled and successfully ran the compiled verson of an app. with a serial interface on a WIN2000 computer with the full LabVIEW development suite.
I installed the LabVIEW runtime engine only on a target computer (running WIN2000) and when I tried to run the app. got the following error -
arning -1073807202 occurred at an unidentified location.
Possible reasons:
VISA: (Hex 0xBFFF009E) A code library required by VISA could not be located or loaded.
(3,126 Views)
You have to install NI-VISA.
It is possible to avoid this seperate install by including all of the required support files.
I believe there is a knowledge base article that lists all of the files that need to be included in your build.
Ben
(3,126 Views)
