What does ERROR 800 (Illegal with storage active) means?
On the second Initialize the program does the sweep and I can see it, and the desired values on the Keithley screen. The problem is after that second initialize, the Kexx measure is not sending dose values I see on the Keithley, to the measure data table and the graph looks very bad.
Message 11 of 12
(1,264 Views)
I just discovered something. The second initialize function is not really an initialize function. It uses the same icon but it is really KE24xx Initiate and thats much different. So, it would seem that the problem is with the measure function. Right click on it and select SubVI Setup. On the dialog box, check the bottom three boxes. Now, the Measure VI will pop-up and be paused. You can experiment with changing the front panels controls (i.e. elements) and run it over and over again without re-running the whole thing. Before you run it the first time, check that the instrument is showing the correct values. If you still can't get it to work, you really need to contact Keithley. All of the actual instrument commands are hidden in the DLL that they wrote and without the source code, it's impossible to determine what's wrong.
Message 12 of 12
(1,260 Views)
