What is the GPIB command required to return phase information from an HP8508A Vector Voltmeter?
The best I could do was to use good old reliable "fetch". However, all that is returned is the Magnitude in the default units of dBuV. Increasing the byte size of the requested data has no effect.
(3,405 Views)
You might find better documentation on the HP8508A command structure in the instrument's manual or from HP/Agilent directly.
(3,405 Views)
