Home
Community
Discussion Forums
Most Active Hardware Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
What is the GPIB command required to return phase information from an HP8508A Vector Voltmeter?
curlyhoward
Member
05-15-2001
08:48 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
The best I could do was to use good old reliable "fetch". However, all that is returned is the Magnitude in the default units of dBuV. Increasing the byte size of the requested data has no effect.
0
Kudos
Message
1
of 2
(3,400 Views)
Reply
Re: What is the GPIB command required to return phase information from an HP8508A Vector Voltmeter?
Ryan_M
Active Participant
05-16-2001
11:10 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
You might find better documentation on the HP8508A command structure in the instrument's manual or from HP/Agilent directly.
0
Kudos
Message
2
of 2
(3,400 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
