Hi Rasheel
Thanks for taking the time to reply! Yes, I know the basics of
the spec file, and how to use it. What I don't know is the
minimal file set. I've got the multiple reboot problem figured
out, if, and it's a big if, I can somehow get the run time (which
translates directly to the size of the zip file I need to load) down to
some small value.
I have what I've named a USB.ZIP and VXI.ZIP file to load. The
VXI.ZIP is the expanded and then recompressed nivxi331.exe file, while
the USB.ZIP is the expanded and then recompressed ni488225.exe
file. The USB.ZIP file is over 365 MB, and it takes too
long. It also has all the documentation, multiple language file
sinks, and other stuff I don't need. Near as I can tell, a Visa
upgrade is required to run the new NI USB-HS driver, but there must be
some subset of all this stuff that is the bare minimum, with no bells,
whistles, or any other sort of extras. That's what I'd like
to try next...pare this down to the minimum and see if what I have will
work.
Got to go. Thanks again for the reply. If you have any
insight into what I can leave out or what I can't leave out, I'd love
to hear from you (or anyone else) again. Remember through all
this that the idea is to upgrade to the GPIB-USB-HS driver, with the
GPIB-USB-B still functional.
Thanks!
Gary
