When configuring my CompactRIO system, I get the VISA Error 0xBFFF00A7 under Remote System>cRIOName>Devices and Interfaces. I checked all the possible causes for this error, but it didn't help. Can somebody help me?
Is this still an issue?  If so, have you verified that you installed your drivers in the correct order?  I'm not too familiar with cRIO, but I've seen another VISA error that was caused by an incorrect order of installation (ie, NI-RIO before NI-FPGA).
(3,462 Views)
Thanks, the problem was fixed. By installing the software for Tektronix Oscilloscopes the library 'visa32.dll' was overwritten, which was used by the NI-VISA. Reenstalling the NI-VISA software solved the problem.
(3,457 Views)
