I am using version 2.2 of the driver.
Using NI Spy, I've included the comunications to and from the GPIB. 3015 to 3021 shows the normal pattern of communications that should occur. Thousands of these can occur without a problem, but if the system load is high, it sometimes fails. The failure is shown in 3022 to 3026. Particularly, compare 3019 and 3026, which are the reading of the header from our instrument, before a data block is read. The 10 bytes read in 3026 do not at all contain the data I expect and also not the values to which the buffer is initialized.
3015. SendSetup(0, {0x0002})
Start Time: 16:05:32.156 Call Duration: 00:00:00.000
ibsta: 0x138 iberr: 0 ibcntl: 3(0x3)
3016. SendDataBytes(0, ".........(", 10 (0xA), DABend (0x02))
ibsta: 0x128 iberr: 0 ibcntl: 10(0xa)
3017. ibcac(GPIB0, 0)
Start Time: 16:05:32.187 Call Duration: 00:00:00.000
ibsta: 0x138 iberr: 0 ibcntl: 10(0xa)
3018. ReceiveSetup(0, 0x0002)
ibsta: 0x134 iberr: 0 ibcntl: 3(0x3)
3019. RcvRespMsg(0, ".......@..", 10 (0xA), STOPend(0x100))
Start Time: 16:05:32.187 Call Duration: 00:00:00.203
ibsta: 0x124 iberr: 0 ibcntl: 10(0xa)
3020. RcvRespMsg(0, "................", 16392 (0x4008), STOPend(0x100))
Start Time: 16:05:32.406 Call Duration: 00:00:00.125
ibsta: 0x124 iberr: 0 ibcntl: 16392(0x4008)
3021. ibcac(GPIB0, 0)
Start Time: 16:05:32.578 Call Duration: 00:00:00.218
ibsta: 0x134 iberr: 0 ibcntl: 16392(0x4008)
3022. SendSetup(0, {0x0002})
Start Time: 16:05:33.281 Call Duration: 00:00:00.109
3023. SendDataBytes(0, ".........(", 10 (0xA), DABend (0x02))
Start Time: 16:05:33.406 Call Duration: 00:00:00.000
3024. ibcac(GPIB0, 0)
Start Time: 16:05:33.578 Call Duration: 00:00:00.656
3025. ReceiveSetup(0, 0x0002)
Start Time: 16:05:34.234 Call Duration: 00:00:00.109
3026. RcvRespMsg(0, "z4.U..s.u.", 10 (0xA), STOPend(0x100))
Start Time: 16:05:34.343 Call Duration: 00:00:00.000
None of our software changes between Win98, where it works, and WinXP, where it fails. It is "only" the OS, and I presume, the NI driver that change.
Also, our software has a small layer between the GPIB driver and the main portions of our software. This is because over the years we've used 3 different GPIB cards. Before settling on NI a few years ago, we used the IOTech card. I cannot duplicate the problem with the IOTech card. This leads me to believe that the problem is in the small layer of our code that calls the NI driver, or in the NI driver itself, rather than in the instrument with which we are communicating over the GPIB. The small layer calling the NI driver was last changed in May of 1999, so perhaps there have been changes in how the driver needs to be called or there is a problem with the driver's interaction with WinXP.
Thank you.
