Where is the documentation for NI4882 in Visual Studio?
I would like some documentation on the methods and properties that are available when using NI488.2 in .NET (I'm using Visual Studio 2010, c#).  The NI help says that it should be under Help>>Contents, but this is not an option in Visual Studio 2010.  Does anyone know where I can find this documentation?
(3,523 Views)
Accepted by RussB
You may want to refer to the Using the Measurement Studio NI-488.2 .NET Library documentation. Also, you can explore the page NI-488.2 .NET Class Library Help for Visual Studio 2010 for examples and other information, which also has a search tool for the applicable methods and properties. This should help you get started!
(3,466 Views)
Thanks for your help - those links provided what I was looking for.  Maybe someday NI will include these links in the GPIB Help that installs with the NI-488.2 drivers.
(3,464 Views)
You're welcome! Glad to help. Also, remember to mark the correct answer to your post for future readers to find these links as well! Thanks
(3,459 Views)
