Whether the analog output can generate PWM waves
Whether the analog output can generate PWM waves by generate  a square wave
(1,466 Views)
Accepted by renfeix
An analog output can have any shape but an ideal square wave has a fixed duty cycle (exactly 50%). Once you do PWM, it's no longer a square wave.
What kind of instrument do you have?
(1,443 Views)
Thank you sir,I have NI 9269 and cDAQ-9178.
Compared with digital output or Counter Output which method is more accurate?
(1,409 Views)
