Which GPIB boards are supported by HP SICL with Windows 2000?EE
Old software has Access violations with HPIB cards want to try National.
(3,068 Views)
SICL only supports HP interfaces. SICL is the low level driver to control HP 488.2 interfaces. For National Instruments interfaces the required driver is NI-488.2.
Both NI and HP support the API (with NI-VISA and HP-VISA). If your application is using VISA (HP-VISA) to control the HP interface, you can switch to NI interfaces using NI-VISA. The API is the same, so there is no need to change the existing code.
Hope this helps.
DiegoF
National Instruments.
(3,067 Views)
