Why I get error -1073807339 when accessing serial port (VISA)?
Why I get error -1073807339 when accessing serial port (VISA)? Software has worked many years and suddenly not anymore. Can it be hardware problem? Or can some updates in the computer cause this problem?
(5,250 Views)
I would suspect a hardware problem first. A timeout err means you are not receiving any data. Check the connection with Hyperterminal to verify that it's not a software problem but then look at the cable and then perform a loopback test on the port.
(5,247 Views)
