This is a recurring problem, but I hope someone has an idea of what may be causing it. I have two older (c. 1992) instruments that we use for simple measurements. One is a Newport PMC-400 actuator driver/motion controller, the other is a EG&G/Princeton Applied Research 5302 lock-in amplifier. I am using Labview 6i with a PCI-GPIB card.
The instruments themselves work fine, and seem to run somewhat reliably if NI-Spy is open. However, if we close NI-Spy, the GPIB seems to "lock up" and time out, requiring resets of all the instruments. This seems to be something related to either command termination or timing.
Any thoughts/hints/solutions would be greatly appreciated.
