Why is my labview executable file not running but the source file runs
I'm using a dell pc and it's not running. It runs when
inside the source code. But compiling it, exe file does not run.
Using clones no problem with exe file.
(3,126 Views)
Nesty,
You're probably going to have a little bit more specific than that. Any error codes??? any particular feature???Installed the run-time engine???
What does "using clones no problem with exe file" means?
Cyril
Cyril Bouton
Active LabVIEW Developper
(3,126 Views)
