Home
Community
Discussion Forums
Most Active Hardware Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
Why is my labview executable file not running but the source file runs
Nesty
Member
03-26-2002
06:56 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
I'm using a dell pc and it's not running. It runs when
inside the source code. But compiling it, exe file does not run.
Using clones no problem with exe file.
0
Kudos
Message
1
of 2
(3,125 Views)
Reply
Re: Why is my labview executable file not running but the source file runs
Cyril
Member
03-28-2002
10:25 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Nesty,
You're probably going to have a little bit more specific than that. Any error codes??? any particular feature???Installed the run-time engine???
What does "using clones no problem with exe file" means?
Cyril
Cyril Bouton
Active LabVIEW Developper
0
Kudos
Message
2
of 2
(3,125 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
