‎08-22-2009 11:08 AM
Hi labview users,
I have so much time working with Labview but and I haven't this problem before, I made a supervisory VI to monitoring and control the complete operation of a conveyor oven, the motors are controlled throught Siemens S7-200 PLC with modbus VIs, and the temperaruture controllers UT351 of YOKOGAWA are comunicating whit modbus too, the VI works ok but sometimes the comunication faults in ramdon mode, and because in ech scan I don't tracing the error signal the comunication should restart but it does'n happens until I restart the complete program or make, I tried aplying a "Clear" at the end of each iteration and the comunication restart automatically but the lost of comunication still happens and despite it's just a instant and almost the operator does not realize that the chart graphics shows a zero point int the lines.
Please I don't know if someone else had this problem before, I am waiting for your advices.
thank you in advance for your support,
WEMAR146
‎08-23-2009 05:14 AM
Just a guess. Can it be a cable fault?
‎08-23-2009 08:46 AM
‎08-25-2009 10:25 PM
Regards...
‎08-26-2009 01:02 AM
