Width/Duty Cycle change
One of the instrument does not set the settings (by the loaded text file), but rather sets to some random large value....
In turn, this causes the VI to a halt without completing the rest of the test program.
I am not sure what is actually causing this behavior.
Can anyone share your thought/experience in a similar situation?
Thanx,
(3,451 Views)
Could you please post more information about this issue:
1)  What device are you trying to communicate with?
2)  Are you using GPIB, Serial, TCP/IP?
3)  What specific setting are you trying to set?
4)  What value are you trying to set it to?
5)  How is the text file being used for this?
6)  What specific error codes are you getting?
Supplying more specific details about the issue can better help us narrow down the cause of the problem.
(3,433 Views)
Without waiting for the answers to the details...
Sometimes some devices need some more time for the setup. If you send strings to fast without waiting for an ACK (if there even are some 😉 things behave weired Smiley Tongue
Greetings from Germany
Henrik
LV since v3.1
(3,423 Views)
Does adding a delay with more time would solve this problem? I am not sure...
(3,391 Views)
How can we know?
Please answer to Michaels Qs and we might be able to help.
Henrik
LV since v3.1
(3,377 Views)
