‎01-31-2005 07:37 AM
‎10-06-2005 10:29 PM
Sorry to ask this in such an old thread for a different device to what we are using, but it's the only one I could find relating to 64-bit support and contained pertinant questions.
@JoshuaP wrote:
Windows XP 64 is not exactly an upgrade for the current Windows XP and we imagine it will take some time before it is adopted. Even though XP 64 is capable of running most 32 bit applications, you will see little benefit in performance with 32 bit applications and Windows XP 64 is not going to support any 32 bit kernel drivers.
Here is a link to an interesting review on the performance benefits of XP 64.
http://arstechnica.com/cpu/03q1/x86-64/x86-64-1.html
In order to utilize the capabilities of Windows XP 64 it will require that every hardware driver in the system be ported and modified to support 64 bit operating systems and you will have to find a way to create a 64 bit application. Current software like LabVIEW 7.1 and MSVC 7.1 will not give you a 64 bit applications and therefore you stand to see very little benefit from actually having a 64 bit OS with most of the current development environments. In addition, if your applications doesn't require more than 4GB of memory and you are not doing mathematical computations that are larger than a 32 integer, note the floating point arithmetic is the same for XP and XP 64, you would still see very little benefit from using XP 64 with a 64 bit application and driver.
However, National Instruments is currently investigating Windows XP 64 and it is a good possibility that it will be supported in the future, but there are no current beta drivers available. The speed at which it is supported will be largely dependent on the amount of valid customer requests and the number of customers that will be using Windows XP 64. From what I understand XP 64 is expected to release sometime around the middle of the year, but it will only be an option on some of the larger server and workstations.
If you can, please give me some more information about you application and how you plan to use to develop the application. Why do you feel that you need Windows XP 64 support?
Joshua Prewitt
‎10-07-2005 11:58 AM
‎10-18-2005 05:40 AM
Thanks Jason, I've applied for the beta program (and am awaiting approval) and have submitted the request on the Product Suggestion Centre link.
@JasonS wrote:
Hi Jason,
As far as beta drivers for your PCI-6601, you could apply for the NI-DAQ beta program at www.ni.com/beta. I cannot guarantee that there is currently a beta program in progress for the drivers you are interested in, but this would be the correct method to obtain beta drivers.
I would recommend that you visit our Product Suggestion Center at the link below in order to let National Instruments know of your interest in these drivers:
http://digital.ni.com/applications/psc.nsf/default?OpenForm&temp1=&node=
‎12-08-2005 10:48 AM
I would like to add my voice for requests to support 64bit. I do have a legitimate need. Xp64 may not be a real upgrade (no real performance benefit), but it DOES eliminate the 2GByte process addressing limit, and this is what I am interested in.
I have found drivers for all my hardware easily enough, more and more devices are supporting drivers for 64bit, and more and more PC's are 64 bit capable (AMD Athlon 64, Opteron, Intel with Em64t). My project had a custom inhouse designed PCI card that I wrote the original 32bit driver for. It took me all of 4 hours to port and fully test the driver under 64bit.
The one sticking point in being able to deploy this is that we need GPIB, and NI is not delivering. I can see that consumer adoption of 64 bit may be a while, but I think in business or embedded applications that 64 bit will be more popular, and that is where GPIB is needed.
‎12-09-2005 09:58 AM
I want to encourage the community to keep discussing the 64-bit version of XP on this thread. The information and various customer use cases are valuable to making decisions regarding this technology. At this time, however, I don't believe that there are any drivers that have true XP 64 bit support in customer beta (I could be wrong about other drivers, I techincally speak only for GPIB). We are actively working on solutions for this and other newer Windows technologies.
It seems that the 4GB+ memory limits are the most attractive feature to posters so far. Anyone else?
Scott B.
GPIB Software
‎12-09-2005 10:50 AM
I certainly see other large companies that make PC hardware supporting 64bit, some have been for a long time. Most of the bigger video card makers do (ATI, NVidia, etc). Even an older USB to serial adapter have 64 bit drivers. I have a nearly two year old Dell Precision 470 workstation, and it runs XP 64, and I can find ALL the drivers for it, including network, audio, video and chipset.
I would have thought that NI would be more proactive. With Vista coming out next year, which will also support 64 bit, seems like now is the time to get started.
‎12-09-2005 02:10 PM
‎12-12-2005 05:07 PM
‎12-12-2005 09:41 PM
