Winows cannot recognize NI GPIB card
Recently I removed a GPIB card from an old computer and installed it in another computer but it seems that the computer cannot recognized this GPIB card. There is nothing shown in device manager and nothing in MAX. The card is PCI-GPIB 183617G-01 (of year 1998). It's a pretty old card but it worked fine with the old XP computer. I followed instruction of how to completely uninstall and then install the card but it doesn't work. I also tried plugging it in different PCI slots and even in another working computer. Nothing showed up. Then I found another similar card 183617K-01 (year 2001) and tried installing it but still no good. I think the chance that both cards and all PCI slots I tried are bad is pretty low. There should be something wrong during the whole process. Does anyone have any ideas what might have gone wrong? So far the only thing I'm suspecting is that all the computers I tried use 64bit Win7. Is it possible that these old cards are not compatible with Win7?
Thanks!
(5,468 Views)
What version of NI-488.2 did you install?
(5,466 Views)
The latest one, NI 488.2 3.1.2
(5,457 Views)
Actually, I just found that this is not the latest one. Do you recommend installing the latest one or going back to older version?
(5,455 Views)
You can try the latest driver but I believe that the one you have should work.
(5,448 Views)
