continuously check Keithley 6517A to REL instantly after Z-Check completes and first measurement is made
I am using a Keithley 6517A to measure charge (Coulombs) via an IEEE 488 connection to LabView. Before a measurement can be taken, however, I need to zero-check (Z-Check, Zch) the instrument and set the relative (REL, Key 30) as soon as the first reading is displayed. If the instrument is still measuring the initial zero-value to which all other values are taken relative to, activating REL will return an error. So I need to send the commands:
: Syst : Zch OFF;
: Syst : Key 30       (without spaces, this dumb setup turns the script into emoticons)
Where the second command (: Syst : Key 30) is not activated until the instrument has measured it's first reading. In other words, I need to continuously query the divce to tell me when the instrument has made it's first reading, then turn on the REL. Any advice on the matter is greatly appreciated! I have attached the Keithley 6517 vi's for reference.
(4,666 Views)
Try experimenting with different wait times to send the second command. The user manual for the device might have more information regarding this.
RF R&D
(4,620 Views)
Hi Bumblebee_Tuna,
Thanks for your advice. I have tried a few wait times, but it's fairly inconsistant over many meausrments. I did however manage to trigger a measurement then by simply using the GPIB Read VI with an unlimited timeout followed by the Key 30 within a case structure, the system took the REL instantly after the triggered measurment was read. I hope this helps anone in the future who may encounter the same problem.
(4,604 Views)
