a communicationinterface problem
HI
I created an .exe  comm RS232  interface (GUI) for my client in japan
on the 8.5.1 version
i sent him the LabVIEW85RuntimeEngineFull.exe too.
the installation passed OK
and the GUI opened OK and the comm was found.
but the transmission failed and no RX /TX  data was exhibit on screen
when client checked the HW and through hyper terminal SW the comm. from PC-unit operated normally
The EXE was built whith supprtion Japanize
what is the problem in your opinion?
Regards
Yoni Zlotnick
(3,767 Views)
Hi Yoni,
Since your code is also dependent on the NI-VISA driver for the serial communication, could you also verify that he has the NI-VISA driver installed as well?
Fred Visser -- SystemLink R&D -- National Instruments
(3,745 Views)
thanks for the solution
Do you mean the 'visa441runtime.exe'?
Yoni
(3,719 Views)
Accepted by Yoniz
Hi Yoni,
If you've written your code with VISA 4.4.1, then absolutely, that Run-Time engine (driver subset) will work. Otherwise, the latest version of the VISA Run-Time is 5.0.3.
I hope this helps,
(3,702 Views)
