a program for an oscilloscope GDS-840C
hello,
i need a program for an oscilloscope with his caracteristiques ( frequency, off set..)
i'm using an: oscilloscope GDS-840C
labview 8.5
us232
Message 1 of 18
(5,912 Views)
Just use Help> Find Instrument Drivers.
Message 2 of 18
(5,896 Views)
Go here to download the driver:
http://www.gwinstek.com/en/product/productdetail.aspx?pid=3&mid=7&id=51
Message 3 of 18
(5,878 Views)
hello,
I have the driver, i don't know how to make a program for the oscilloscope
thanks
Message 4 of 18
(5,875 Views)
Where are you stuck? How familiar are you with LabVIEW? You should be able to translate a manual setup to a programmatic setup by studying the programming manual and the functions in the driver. I have not downloaded the driver but typically, you turn on context help and get a description of the VI and the controls/indicators.
Message 5 of 18
(5,872 Views)
hi i'm newer with labview , i don't know any thing about it
thanks
Message 6 of 18
(5,869 Views)
Programatic Instrument Setup 101:
1. Setup the scope exactly the way you want it.  WRITE DOWN EVERY STEP.
2.  Find the functions that will do the steps you performed.
3.  Write your code using those functions.
Message 7 of 18
(5,866 Views)
but i don't know the steps to start
Message 8 of 18
(5,864 Views)
You don't know how to work your instrument?  Then get somebody to teach you how it works.  You won't get anywhere until you do.
Message 9 of 18
(5,861 Views)
You don't know how the steps to setup the scope manually from the front panel?
Message 10 of 18
(5,860 Views)
