a program for an oscilloscope GDS-840C
i need just an example to know how to work with an oscilloscope with labview
Message 11 of 18
(2,399 Views)
So do you know the steps you have to do to manually setup the scope?  If so, dig through the palette and find the functions that will do what you want.  You will need to use the Initialize function (assuming there is one) at the start of your program, before any of the other functions.  And then use the Close functions (again, assuming there is on) when your program is done.
Message 12 of 18
(2,393 Views)
I'm getting an error downloading the driver. Drivers from NI always include at least one example. Have you browsed through the unzipped folder to see if there is any example there? For general examples, you can install a scope driver for tek or agilent scopes. Your manual setup would include setting the horizontal, the vertical, the triggering, etc. The same steps need to be done with the driver. Then you initiate a acquisition and fetch the waveform.
Message 13 of 18
(2,391 Views)
the driver
Message 14 of 18
(2,384 Views)
hi
i didn't found the VI to read and write the signal
thanks
Message 15 of 18
(2,366 Views)
hello
i tried to do the program but i did not know how to to do it
thanks
Message 16 of 18
(2,347 Views)
hi please some help
Message 17 of 18
(2,346 Views)
hello,
i did this program, i hope that the program is wright
thanks
Message 18 of 18
(2,338 Views)
