agilent 2000 3000 x-series waveform generator.vi "undefined header"
I am trying to run the example vi "agilent 2000 3000 x-series waveform generator.vi" with LabView 13 but I get "undefined header" error. The example vi "Agilent 2000 3000 X-series Acquire Waveform Continuously.vi" works fine, so I"m comunicating with the DSO-X 3054 scope but unable to control the waveform generator. Any advice will be greatly appreciated. Thanks.
(5,718 Views)
Hi wtoso,
The "undefined header" error is typically due to an incorrect GPIB command or value. Please make sure you are providing the device with the correct command. Details on GPIB commands for Agilent scopes can be found on the company website, in the programmer's manual.
Kristen M
Automated Test Product Marketing Engineer
(5,691 Views)
Accepted by wtoso
I updated the firmeware on my DSO-X 3054A scope and now it works. Thanks.
(5,687 Views)
Same problem is with me also, when I open series waveform generator.vi connecting agilent X-20004A DSO via lan , it shows error 113 undefined header, wave form does not get generated over DSO.
(3,253 Views)
