agilent 33500B duty cycle configuration
I am using the Agilent/Keysigt 33511B function generator to produce a square wave with specified amplitude, frequency and offset. However, I am unable to configure the duty cycle. Is there a VI to controll this parameter?
(4,182 Views)
Accepted by jmountney
Hi jmountney
If you are using this Driver I think there is a function named Configure Standard Waveform Advanced (square) .vi  and it has an input for Duty Cycle so I think it might help you.
(4,117 Views)
