agilent dso5034a waveform
Hello All,
I have an agilent dso5034A which uses the agilent 600A library provided by NI.  What I am trying to do is the following, I have a continuous waveform (a square wave)  current generator with a specific pulse width and duty cycle.  What i want to do, is measure the current and voltage on the resistor. I am able to see the waveform on the scope when i do it manually and am able to determine this by hand, but i would like to do this in labview. The issue I am running into is trying to acqure only one of the waveforms and not a series of them. I.e. _| |__| |_    i sometimes have two pulses but i am only interested of one of them, it doesn't matter which one i get, as long as i get the corresponding voltage. Does anyone have an idea how to just look at one pulse?
Thank you
(3,073 Views)
Hi
try to change the timebase value such that it is equal to the time period of the pulse
Check edge triggered  acquisition example
Regards
Message Edited by appala on 03-23-2009 12:02 AM
(3,053 Views)
