always VI_ERROR_RSRC_BUSY on reads, can't recover
The 2014B works reliably, except for 2 issues which might be due to my OS (SuSe 10.2 Linux) or computer hardware:
1)  I need a USB hub between my computer's USB port and the oscilloscope.  The ones we use have 7 or 8 ports and are available from D-Link for a fairly low price.
2)  I have trouble setting the permissions for the device via udev.
Problem #1 occurs on two different computers running SuSe 10.0 and SuSe 10.2.  Both computers are from the same source (Pogo Linux) and use libusb 0.1.12.
Problem #2 occurs under SuSe 10.2, but not under SuSe 10.0
Sarah Messer
gamer, physicist, programmer
Message 31 of 32
(1,490 Views)
you said that " My driverwizard had the USB connection option greyed out but there were USB-like options in the PXI/PCI screens which I used instead. "
I have the same problem. Could you please specify which options you used for USB?
J.
Message 32 of 32
(969 Views)
