01-27-2007 02:29 PM
01-27-2007 03:17 PM
You would only need two DAQ cards if the DAQ cards you are using only have a single channel and NI doesn't make single channel DAQ cards.![]()
If you are using DAQ Assistant, use only one assistant but specify two channels. If you are using the regular DAQmx functions, use a single DAQmx Read and with a single DAQmx Create Channel, have two channels in the list. The syntax would be Dev1/ai0:1. You can easily select multiple channels by clicking the arrow on the right side of the channel list control and selecting browse.
p.s. You need to post similar questions to the Multifunction DAQ forum. This forum is for instrument control (i.e. GPIB instruments).
01-28-2007 09:56 AM
01-28-2007 09:23 PM
