‎11-03-2009 02:31 PM
Solved! Go to Solution.
‎11-03-2009 03:00 PM
‎11-03-2009 03:36 PM
‎11-03-2009 04:08 PM
‎11-03-2009 04:35 PM
‎11-03-2009 04:47 PM
‎11-04-2009 08:44 AM
‎11-04-2009 08:48 AM
You only need the additional installers if you are creating an installer for the exe but I thought you said it does not work on the development pc? If that's the case, you are wasting your time.
Do you have any error handling in the exe? If so, what error code is being reported? When running the exe, do you have LabVIEW open?
‎11-04-2009 09:17 AM
"When running the exe, do you have LabVIEW open? "
DOH!
mumble mumble mumble........
‎11-04-2009 01:52 PM
