attribute for USB device description from the inf file
I have created an inf file for a USB device with the NI driver wizard.
During this process i entered a device description. This description can be seen in the inf file in the section [Strings] like:
USB\VID_XXXX&PID_XXXX.DeviceDesc="My Device Description"
This device description is also shown in the windows device manager in the category "NI-VISA USB Devices".
I want to read the device description from the inf file with a VISA function like GetAttribute.
But i was not able to find the attribute which gives me the device description from the inf file.
Is there an attibute or other function to get the device description?
(3,385 Views)
you can use the MAX API in LabVIEW.
Example: I have an USB handscanner from metrologic. The device description in the INF file is "Metrologic Scanner".
Hope this helps!
Cheggers
Sascha
(3,378 Views)
Is there also a solution just using the VISA API?
(3,365 Views)
