ayesha.ist@gmail.com
Actually I have to implement RS485 on DSP. I have TI C6713 DSP Kit. In order to use Labview for 485 implementation Can I use TI DSP board or I have to buy NI board.?
If I use 8051 microcontoller instead of DSP then can I use labview?
(4,744 Views)
As long as your device is RS485 compatible LabVIEW should be able to communicate with it. You will need the NI-488.2 and NI-VISA drivers installed to do RS485 communication. You can find these on our web site at http://www.ni.com/support/.
The following is an example of RS485 loop back test to get you started on RS485 code.
RS-485 Loopback (Port to Port) Test 2 Wire AUTO MODE ONLY
-Scott
(4,715 Views)
The targets supported by the DSP add-on are listed here.
(4,710 Views)
