marconi 6500 vs probe non original
hi, all
 on marconi 6500 I try to connect detector negative nn Marconi but problem....
secon problem :  marconi 6313 sweep connect marconi 6500 on gpib do not sweep...
procedure init/ local etc is ok ..
thanks to all
(4,003 Views)
Sorry,
could you explain more clearly your problems.
Cheers
M
Matteo Brunella
Application Engineer
NI Italy
(3,987 Views)
thanks...
I buy on ebay marconi 6500 fault, then find many tantalium cond. breakdown !!
sobstitution of all tantalium ...
marconi seems OK now
but connected with sweep 6313 and using detector non original  I see level 0dbm and attenuator function ( -10, -20 etc) but filter response not! seems no sweep ?! or no sinc? or not original probe do not active sweep ?
I try with ifr sensor 62 series bat is too new for old 6500 series
thanks
(3,985 Views)
Hi fsartori,
please forgive me but I can't understand how your problem relates to National Instruments products: 6500 and 6313 are both produced by Marconi, I think you should address their support.
Lucius
(3,972 Views)
