bias resistor to NI8431/8
.I have a PCIe 8431/8 card and I want to put bias resistor on it .But I could not understand on which pad do I have to use for soldering the resistor.Could you please help me about the pad ID of bias resistors?I think the marking on PCB "UL94V-0 198108B-02 "gives you idea about the version of the PCB.
(3,356 Views)
Hi serialdaq,
We recommend that for this particular card you add the bias resistors externally.
Thank you!
Chris T.
(3,339 Views)
