cRIO 9002 Problems to read on the onboard serial port
I have some problems to read serial data on the onboard port of my cRIO. I built a VI modifying the LABVIEW example "basic serial read.vi", but I have the following problems :
                    - The timeout starts always at the end of the data read and cause an error
                    - Data are posted in the string window only after the timeout start
If someone has already known this problem, and can help me or if someone has an example of an simple cRIO serial read, that could help me much.
Thanks for your attention, and sorry for my little English.
Julien M
(3,293 Views)
Sorry, I have forgotten to precise that I work with LabVIEW 8.2
thanks
(3,291 Views)
