capture a low frequency sinusoid with PXI-4132
I would like to drive a 275Hz 2V amplitude 2V offset above ground sinusoid into the sense hi lo pins of the  PXI-4132 & try to capture it to do an FFT & look at the quality of the waveform.
I have tried to drive those pins directly without luck.
I then tried to drive the hi lo pins as well, with the compliance set low enough to overdrive the inputs.
I would  also  like the PXI-4132 to generate this sinusoid for driving a DUT.
This card sits in a PXIe-1073 chassis connected to an windows xp PC runnig labview 2011 SP1.
Any help would be appreciated.
(4,335 Views)
Best to ask this question in the Multifunction DAQ message board.
(4,312 Views)
