12-03-2014 03:15 PM
I would like to drive a 275Hz 2V amplitude 2V offset above ground sinusoid into the sense hi lo pins of the PXI-4132 & try to capture it to do an FFT & look at the quality of the waveform.
I have tried to drive those pins directly without luck.
I then tried to drive the hi lo pins as well, with the compliance set low enough to overdrive the inputs.
I would also like the PXI-4132 to generate this sinusoid for driving a DUT.
This card sits in a PXIe-1073 chassis connected to an windows xp PC runnig labview 2011 SP1.
Any help would be appreciated.
12-04-2014 07:47 AM
Best to ask this question in the Multifunction DAQ message board.
