Is there a way to do this in a clean way? e.g. that the status-bits are used
to detect the beginning and finalization of a transfer (by use of ibwait
prior to reading or writing). I found that the LACS and TASC bits are not
reset after completion of a transfer...
Mike Tranchemontagne  wrote:
>This is a multi-part message in MIME format.>--------------CC52921529A8C94F0C665CB6>Content-Type:
text/plain; charset=us-ascii>Content-Transfer-Encoding: 7bit>>I did this
some years ago in QuickBASIC and later in Visual BASIC.  It's not>hard and
NI even has an App Note that describes this...>>One GPIB is programmed in
the normal way.>>The other is NOT a system controller, and board level (vs.
device level) IBWRT>and IBRD calls are used.  Just put the IBRD and IBWRT
in a loop, and use a>short timeout, like 100 milliseconds.  Most of the time,
they will timeout,>just ignore it and keep looping.  When you DONT get a
timeout, then you know>the GPIB controller (in the other machine) sent or
received something.  I used>some global variable for send and receive buffers.
 When IBRD eventually>didn't timeout, then I knew my RD$ buffer had a new
message from the>controller.  When I wanted to send something, I used SND$
and when IBWRT>eventually didn't timeout, then I knew the controller had
received my message.>>Good luck!>>henning hummert wrote:>>> hi,>> i have
2 gpib-boards on two different machines. i am trying to communicate>> between
the cards. unfortunately i have timing problems. the boards will>> lock up
after a very short time.>> does anybody have programmed something like this
in an ms c++ environment?>> basically i just want to use the cards to send
data fast between the two>> pcs.>>>> any ideas are highly appreciated.>>>>
h>>-->Best Regards,>Mike T>>Mike Tranchemontagne>Consulting Applications
Engineer>TeraComm, Inc.>148 Main Street>Building A, 3rd Floor>North Andover,
MA 01845>877-900-TERA (8372)>978-557-9490 (FAX)>603-598-4773 (Direct Line
and Cell)>>>--------------CC52921529A8C94F0C665CB6>Content-Type: text/x-vcard;
charset=us-ascii;> name="miket.vcf">Content-Transfer-Encoding: 7bit>Content-Description:
Card for Mike Tranchemontagne>Content-Disposition: attachment;> filename="miket.vcf">>begin:vcard
>n:Tranchemontagne;Mike>tel;fax:978-557-9490>tel;work:877-900-TERA  or  603
598-4773>x-mozilla-html:TRUE>url:http://www.teracomminc.com/>org:Sales;TeraComm,
Inc.>version:2.1>email;internet:miket@teracomminc.com>title:AE>adr;quoted-printable:;;148
Main Street=0D=0ABuilding A, 3rd Floor;North Andover;MA;01845;>note;quoted-printable:877-900-TERA
is toll free to TeraComm sales office =0D=0A=0D=0A603
>598-4773  is home office and forwards to cell phone>fn:Mike T>end:vcard>>--------------CC52921529A8C94F0C665CB6-->
