07-20-2007 08:16 AM
I am using a tektronix TPS 2024 oscilloscope. I have currently connected it to an AC supply and am trying to acquire continuous data from it into signal express version 2.0. I cannot get signal express to auto update changes in the amplitude. I have to hit run once every time I change the voltage. Also when I hit run, signal express just goes into a running stage and doesn't do anything. It is as if it hangs.
07-23-2007 08:08 PM
Hi smm,
I will need a bit more information to help me to troubleshoot your issue . Are
you able to acquire any reliable data from your acquisition? At the beginning
of your post it seemed that you were able to acquire one data point at a time
but were having trouble with a continuous acquisition, but in the last line of
your post it sounded like nothing was working at all. Perhaps you could provide
me with a brief description of what is and what is not working, along with the
steps that you are using in SignalExpress for your application.
07-24-2007 06:25 AM
07-25-2007 04:01 PM
In order to set up a continuous acquisition in Signal Express you will need to make sure that you set the Acquisition Mode to Continuous Samples and then use the Continuous Run button to start the application. Is your application set up this way?
07-26-2007 06:12 AM
I believe it is. Is there anything specific to be done, to set it to N samples?
Also, can a waveform be saved to be printed later?
07-27-2007 04:40 PM
