continuously stream data through ethernet to a device
Hey,
I want to stream data from PXI controller through ethernet to a remote device. How can i do it? Any examples?
(4,278 Views)
Hi Alann,
What is the remote device?
You can send data using the TCP or UDP VIs (Data Communication»Protocols).  You may want to use UDP since it's not connection based, unlike TCP.  If losing data is a concern, TCP is lossless.  If you need some examples, open the NI Example Finder (Help»Find Examples...) and search for UDP or TCP
(4,257 Views)
Ok great! I tried those and they work. What is the maximum possible data rate I can achieve?
 Remote device for now is another PC. I am using 1 Gbps Ethernet cable.
Message Edited by Alann on 01-21-2010 04:21 AM
(4,244 Views)
Hi Alann,
Ideally, the rate you could achieve is the maximum supported by the network card (1 Gbps).  Because of network topology, network traffic, operating systems, etc., I don't know what the exact number will be.
Take a look at this example to test your connection:   http://sine.ni.com/devzone/cda/epd/p/id/4692
(4,221 Views)
