control digital potentiometer SPI
thank you very much for your good explanaton 🙂
I'm sorry I'm very slow of getting all of this but can you give me an example in .vi what I must do first to do this? I search in SPI Digital Waveform Reference Library discussion for a similar goal but I do't seem to find it 😞
thank you
Message 11 of 14
(1,479 Views)
Try changing your Digital Write to Digital 1D U32 1Chan NSamp. When you select Polymorphic type the menu chain is Digital >> Single Channel >> Multiple Samples >> 1D U32 (port format).  I do not have DAQmx so the details might be slightly different
The image below shows a modification to a portion of your AD8402.vi.
Can't load image now = Flash is blocked due to security issues.  I will try again later.
Lynn
Message 12 of 14
(1,467 Views)
Here is the image.
Lynn
Message 13 of 14
(1,462 Views)
I really appreciate your help. thank you 😄
Message 14 of 14
(1,451 Views)
