controlling a USB to I2C module from visa
Hi, Here is my situation: I have a USB to I2C adapter built using a Silabs microcontroller. The physical connection to that is done obviously via an USB cable. I want to send/receive information to/from it using NI-VISA. I created an USB driver for RAW usb device and installed  it. Everything works fine and in the Measurement and Automation Explorer I can see my device listed.Now I have put together  the following code to communicate with my USB to I2c module:#define MAX_CNT 200ViChar buffer[MAX_CNT];                                         /* Buffer for string I/O */ViSession rsrcMgrHandle, instrHandle;                         /* Communication channels */ViUInt32 retCount;                                                       /* Return count from string I/O*/ int status; // Open Resourcesif ((status = viOpenDefaultRM (&rsrcMgrHandle)) != VI_SUCCESS) {                        /* Error Initializing VISA...exiting */                         return -1; }if ((status = viOpen (rsrcMgrHandle, "USB0::0x10C4::0x84D6::FF::RAW", VI_NULL, VI_NULL, &instrHandle)) != VI_SUCCESS) {                        /* Error Initializing VISA...exiting */                         return -1; } //Ask the device for identification if ((status =viWrite (instrHandle, "*IDN?\n", 7, &retCount)) != VI_SUCCESS) {                        /* Error Initializing VISA...exiting */                        return -1;          }….….// Close Resourcesif ((status = viClose (instrHandle)) !=VI_SUCCESS) {            /* Error ClosingVISA...exiting */            return -6;                                    }if ((status = viClose (rsrcMgrHandle)) !=VI_SUCCESS) {            /* Error Closing VISA...exiting */            return -1;} I need to transmit a command that in c looks like: int WriteCmd(unsigned char cmd, int device, int address, int numBytes, unsigned char* buffer)
Can anybody tell me haw would I do that? Any examples of similar programs ?
Many thanks,
ZZippo
(3,431 Views)
Hello Zzippo,
As you created a duplicate post, we will be posting on this thread below instead to help you through:
http://forums.ni.com/ni/board/message?board.id=140&message.id=39080
Kind Regards,
Michael S.
Applications Engineer
NI UK & Ireland
(3,410 Views)
