‎11-15-2011 04:25 AM
i have created program using NI labview trail version software and the hardware i am using is NI Compact RIO hardware. I have build and created EXE file into the Compact RIO hardware Now its working fine whether after 30-days trail version is over whether it works without any problem because the software i am using is a trail version.
Solved! Go to Solution.
‎11-15-2011 04:41 AM
Interesting question. I have used compiled executables fairly extensively and while it is not a direct answer to your question, while I would start writing the program on my computer with a full license and later compile it on that one, I often installed a trial copy on the computer that the executable would be eventually used with so that I could edit and test the code out without having to trek back and forth as much to troubleshoot my programs and I never later had a problem and many times the program was last saved on the trial copy before I copied it over to my PC with the license to do the actual compiling of it. That said I imagine there is a way they could embed the expiration into the executable. Usually for all Demos there is a help or readme file that explains the exact limitations of the Demo version. I wouldn't really recommend relying on it either way because you will not be able to go back and fix or change it later without a full version.
‎11-15-2011 06:29 AM
Thanks a lot sir,but i need clear answer regarding this.
‎11-15-2011 08:08 AM
Please do not post the same question on multiple boards.
