creating software in Labview trail version whether works after 30 days
i have created program using NI labview trail version software and the hardware i am using is NI Compact RIO hardware. I have build and created EXE file into the Compact RIO hardware Now its working fine whether after 30-days trail version is over whether it works without any problem because the software i am using is a trail version.
(3,700 Views)
Accepted by topic author madhankumarlv@gmail.com
Interesting question.  I have used compiled executables fairly extensively and while it is not a direct answer to your question, while I would start writing the program on my computer with a full license and later compile it on that one, I often installed a trial copy on the computer that the executable would be eventually used with so that I could edit and test the code out without having to trek back and forth as much to troubleshoot my programs and I never later had a problem and many times the program was last saved on the trial copy before I copied it over to my PC with the license to do the actual compiling of it.  That said I imagine there is a way they could embed the expiration into the executable.  Usually for all Demos there is a help or readme file that explains the exact limitations of the Demo version.  I wouldn't really recommend relying on it either way because you will not be able to go back and fix or change it later without a full version.
(3,699 Views)
Thanks a lot sir,but i need clear answer regarding this.
(3,688 Views)
(3,673 Views)
